66 jetaway throttle control plug help
I have switched out my old trans for a recently rebuilt trans but I have an issue where my old trans has a double plug for the kickdown but the other one is a single plug
You can do this down by the transmission and just connect the wire that only provides power at WOT. The other wire will provide power at idle and WOT. You can us a 1/4 female spade terminal and heat shrink.
That was my point. The 1.76:1 first gear in the Junkaway is almost like starting in second gear in a normal trans. The added torque multiplication afforded by the switch pitch mitigates that somewhat. He loses that with the replacement.
Thanks guys for the input .
if I’m loosing that much off the bottom end I will probably just pull the trans and put my original back in .
like I said nothing wrong with it shifts well lust needs a pan gasket installed
