67 cutlass 330 kickdown switch
Old October 7th, 2007, 01:05 PM
nevadacutlass's Avatar
Does anyone know where I might find a kickdown switch(carb throttle end) for a 67 Cutlass Supreme 330 w/two-speed? Estate car, everything works except this switch and rear electric radio antenna.
nevadacutlass is offline
Old October 7th, 2007, 06:31 PM
Your only option for a factory-type switch is to find a good used one. Any 64-67 Cutlass/F85/442/Vista Cruiser with an automatic will have one. Alternatively, you can get an aftermarket switch that goes on the carb lever and does the same thing. Do you have the switch-pitch trans or not?
joe_padavano is offline
Old October 8th, 2007, 07:28 PM
Thanks - yes, know they are not available from ACDelco, just hoping someone might has NOS on the shelf somewhere, or used. I 've got a good transmission guy looking through his sources, just trying all options. Not sure about the aftermarket option - do you mean there were actually some made, or that it might work to jerry-rig something? Don't now about the switch-pitch...does it make a difference for the switch? Its definately a 67 2-speed.
jstrits
January 4th, 2014 04:05 PM
Sid
October 11th, 2011 10:18 PM
Flye
July 15th, 2009 09:25 PM
Satellitecentral
March 18th, 2009 05:38 PM
nevadacutlass
October 7th, 2007 01:14 PM
Quick Reply: 67 cutlass 330 kickdown switch
