67 cutlass 330 kickdown switch
Does anyone know where I might find a kickdown switch(carb throttle end) for a 67 Cutlass Supreme 330 w/two-speed? Estate car, everything works except this switch and rear electric radio antenna.
Your only option for a factory-type switch is to find a good used one. Any 64-67 Cutlass/F85/442/Vista Cruiser with an automatic will have one. Alternatively, you can get an aftermarket switch that goes on the carb lever and does the same thing. Do you have the switch-pitch trans or not?
Thanks - yes, know they are not available from ACDelco, just hoping someone might has NOS on the shelf somewhere, or used. I 've got a good transmission guy looking through his sources, just trying all options. Not sure about the aftermarket option - do you mean there were actually some made, or that it might work to jerry-rig something? Don't now about the switch-pitch...does it make a difference for the switch? Its definately a 67 2-speed.
jstrits
January 4th, 2014 04:05 PM
