'71 Cutlass TH350 Kickdown Q's
Old February 1st, 2020, 06:10 PM
highschoololds's Avatar
I've had the car torn down for a while and can't remember. I think the guy who did the transmission put the wrong kickdown cable in.
Looks like I'll need a replacement and a crash course in all things kickdown.
The cable goes from accelerator pedal to transmission correct? Only thing going to carburetor is the throttle cable itself, no transmission linkage, correct?
Adjustment procedures?
Thanks,
Josh Hucks
highschoololds is offline
Old February 1st, 2020, 06:18 PM
66SportCoupe's Avatar
Yes goes from transmission to accelerator pedal on TH 350. There is no adjustment. This only a kickdown cable it does nothing else.
66SportCoupe is online now
Old February 1st, 2020, 06:50 PM
Actually, there is an adjustment on the kickdown cable. The end of the cable that attaches to the accelerator pedal terminates in a short metal rod. A spring clip fits over this rod to allow the cable to be pulled when the pedal is floored. You can adjust the position of that clip on the rod.
joe_padavano is offline
Old February 2nd, 2020, 06:23 PM
Knowing what kind of car your working with would help. Some cars have the kickdown cable on the carb, some go thru the firewall to the throttle pedal as joe mentioned. The kickdown cable travel should max out around WOT, either adjust the clip or bend the throttle bracket.
matt69olds is offline
Old February 3rd, 2020, 08:19 AM
He listed 71 Cutlass in the title of the thread.
Old February 3rd, 2020, 11:58 AM
um, I missed that. I hang my head in shame
Old February 5th, 2020, 06:28 AM
Thanks for the help. The cable actually appears correct, albeit a bit long. But I think it’s workable.
Crockett 999
April 27th, 2015 07:57 AM
71cutlass350
August 7th, 2013 09:11 AM
archerbob
September 12th, 2011 01:29 PM
rocketscientist
April 29th, 2010 08:13 PM
bigbrother
June 18th, 2007 12:34 PM
Quick Reply: '71 Cutlass TH350 Kickdown Q's
