71 Olds Cutlass Trans linkage
Old August 9th, 2003, 05:58 AM
<Cody>
Guest
Posts: n/a
Post
I have a '71 Cutlass w/ an auto with shift on the floor concole. When I shift into park it does not fukky engage the linkage to steering column. What I manually must do at that point is turn the steering column so it will start. I think they must have designed the column shift first for powerglide type units and subsequently added the floor shift unit later. Is there some linkage bushing that I can replace?
Old August 10th, 2003, 10:00 PM
70ragtop's Avatar
Post
This is a common problem on the 69-72 cars. This feature was not even used on Jetaway (powerglide) cars. There is a bolt under the car where the column linkage attaches to the trans linkage. loosen this bolt and slip column housing all the way to the left (counter clockwise) with the shifter in park, then tighten the bolt. This should fix the problem.
My 72 Supreme does this, and I am just too lazy to fix it...lol.
Hope this helps.
70ragtop is offline
jstrits
January 4th, 2014 04:05 PM
Wilson
August 3rd, 2012 06:21 AM
gearheads78
August 6th, 2008 07:44 PM
granddaddy-O
May 14th, 2008 08:27 AM
sborruso
November 20th, 2007 04:11 PM
Quick Reply: 71 Olds Cutlass Trans linkage
