Auto to T5 Manual Swap Help Please
Old October 12th, 2012, 01:09 PM
Propaneking's Avatar
Someone who has done an auto to T5 swap willing to help with some question? 1972 Automatic 350 motor convertible.
Propaneking is offline
Old October 13th, 2012, 11:23 AM
2blu442's Avatar
If nobody's replied to this yet send me a PM and I may be able to help.
John
2blu442 is offline
Old October 21st, 2012, 09:13 PM
The_Jeremiah's Avatar
do yourself a favor, dont use a T-5, you will break it. you might be alright with a world class t-5, I wanted an overdrive trans, through a bunch of research I decided on the T-56 If you want to swap to a manual, you will need the pedal box, linkage, trans, crossmember, one of the problems with the oldsmobile engines is the crankshaft isnt drilled for a pilot bearing. I know theres a few people that have found easy solutions to this. someone will chime in
The_Jeremiah is offline
Old January 16th, 2013, 06:00 PM
1964f-85's Avatar
I have a WC T-5 out on a 86 Mustang GT in my F-85. I rebuilt it with stronger internals, but summit has an equal replacement for about $1200.00. I drilled my crank using a jig that we made to center a bit on the crank. The hard part is that you will need to machine an adaptor plate that moves the transmission back. The plate bolts to the BOP belhousing, and has the ford bolt pattern. Everything else is stock. Not easy! I would convert to a muncie first.
1964f-85 is offline
Old March 1st, 2013, 10:53 PM
65B01Delta's Avatar
I would like to see a picture of the jig you made. I have a crank that I need to drill...
Thanks,
65B01Delta is offline
Old March 2nd, 2013, 07:06 PM
Pat McClelland's Avatar
If you machine a plate to move the tranny back you can put the pilot in a spool machined to center in the flywheel. Porche does this and I have used it to hook a t-56 to the 371 motor in my 57. My t-56 was an aftermarket version intended for Mustangs and came with a 1/2 inch steel plate on the trans which we drilled for my Offenhauser bell housing.
Pat McClelland is offline
68cutS
August 16th, 2015 06:17 PM
jon69olds
November 4th, 2010 11:11 AM
DaGOONIE
Drivetrain/Differentials
August 29th, 2008 12:25 AM
cruznn
September 24th, 2007 07:09 AM
drtdobber
February 14th, 2007 01:16 PM
Quick Reply: Auto to T5 Manual Swap Help Please
