Clutch fork and throw out bearing
Old January 9th, 2024, 11:22 PM
BondAR's Avatar
I have found that when I install the throw out bearing(centerforce n1716, also 614018) in the reproduction fork, the flange of the bearing extends past the flats ground onto fork tips. Will this cause a problem, or should I grind/file the flats wider as to allow for better contact on the bearing flange? This is my first time installing clutch components as I am in the final stages of converting my auto into a manual stick shift. Here are a couple of pictures. Thanks.
BondAR is offline
Old January 10th, 2024, 04:16 AM
joesw31's Avatar
The original forks are not grounded in that area. They look like that when there worn out. Appears the repro fork was reversed engineered from a badly worn fork.
joesw31 is offline
Old January 10th, 2024, 09:08 AM
BondAR's Avatar
Thanks for the response, that's unfortunate. I'll try to source another or at the very least try to weld it up.
BondAR is offline
harriscu
January 3rd, 2022 03:06 PM
4SPEED67
April 9th, 2018 06:40 AM
alburk
December 13th, 2015 12:59 PM
1978 Oldsmobile Omega
August 13th, 2015 07:12 AM
Cincinnati Rick
August 3rd, 2015 07:08 PM
Quick Reply: Clutch fork and throw out bearing
