Dextron VI
Old August 3rd, 2017, 04:29 PM
radioburningchrome's Avatar
Dextron VI
Went to get a few quarts of transmission fluid and all Napa stocks is D6. Back label states its compatible with D1, D2 and D3. What happened to Dextron 4 and 5?
Is this correct for my 1997 88?
radioburningchrome is offline
Old August 4th, 2017, 07:03 AM
That is an appropriate transmission fluid for your 97 88. I believe those were designed for Dexron III.
I don't think I've ever seen a Dexron IV ATF. I know I've seen Dexron V in the past. The auto manufacturers just update fluids every so often.
Most parts stores carry universal ATF now. I suppose it works just as good as Dexron. When I was in college I recall guys rebuilding their TH350s and putting Type F ATF in it. It was supposed to be the cheap man's way of getting a fluid that worked more like Trick Shift. I just always used Dexron III. Of course, at the time I owned my 64 Olds 98 with a Slim Jim Rotohydramatic. That transmission is such a POS...
Olds64 is offline
Old August 7th, 2017, 05:20 AM
'87 Delta 88 Royale
rustyroger's Avatar
I understand Dexron V1 is backwards compatible with all previous Dexron transmission oils from Dexron 11 up.
To put your mind at rest why not contact the Dexron website and ask?. I have had helpful information from UK oil companies, no reason why Dexron (or whoever owns it) shouldn't help you.
Roger.
rustyroger is offline
Old August 8th, 2017, 04:12 PM
Roger.
My questions are usually answered quickly here. My time is limited, even for internet!
Great. Thanks!
Old August 8th, 2017, 06:28 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I have been using Dexron IV in my 2004R's and 4L60E with no issues. Even had a mix in my 2004R.
olds 307 and 403 is offline
Old August 8th, 2017, 07:08 PM
Tedd Thompson's Avatar
As I understand it all Dextron numbers are inter changeable. This has been discussed many times before. ... Tedd
Tedd Thompson is offline
Old August 24th, 2017, 04:47 PM
Thanks for the "real life" info.
Old August 24th, 2017, 06:27 PM
One thing I can tell you, run a trans low on fluid, it doesn't matter what fluid was in it.
Old March 22nd, 2018, 10:18 AM
69455's Avatar
I believe 4 & or 5 are synthetic
69455 is offline
