fitting leak
Old March 25th, 2009, 06:10 AM
miho35o's Avatar
fitting leak
i noticed that a small fitting on the drivers side of my TH400 transmission is leaking. it has a hose coming out of it that runs toward the engine. Any idea what this fitting does and what fixing the leak involves?
miho35o is offline
Old March 30th, 2009, 04:52 AM
scrappie's Avatar
Are you sure it is on the drivers side? Is there a wire,hose or metal tube connected to it?
scrappie is offline
Old March 30th, 2009, 06:24 AM
Eric Anderson's Avatar
It took me a while to figure out that the "hose" you refer to is actually the speedometer cable. Follow it to the other end and you'll find it actually passes through the firewall (unless you have cruise control, in which case it will run to a transducer on the inner fender panel). There are two O-ring seals here, one between the housing and the trans case and one internal to the housing that seals the speedo drive gear. Both are easy to replace.
There were two threads on this question, Joe P answered it in the other. Had me scratching my head when I first read it too.
Eric Anderson is offline
miho35o
Ninety-Eight
May 7th, 2009 06:50 AM
Oldsguy
September 15th, 2008 11:08 AM
bjtstarfire
July 26th, 2008 08:41 AM
68Toro
April 4th, 2008 06:04 PM
Olds Nut
September 18th, 2007 07:10 AM
Quick Reply: fitting leak
