Flywheel Inspection Cover
Old February 5th, 2012, 10:21 AM
Formerly "Shimmer"
Al Graaf's Avatar
Am replacing my "missing" flywheel inspection cover. Should it be the same color as the transmission or engine cover? Came from GM parts black. Somewhere I have heard this part was plastic. Got 71 442 TH400.
Thanks!
AL
Al Graaf is offline
Old February 5th, 2012, 10:42 AM
Lady72nRob71's Avatar
I think they were all black plastic. The 350's are for sure for that year.
I assume you mean this lower part:
Lady72nRob71 is offline
Old February 5th, 2012, 04:36 PM
Formerly "Shimmer"
Al Graaf's Avatar
Great picture Rob. Yes that's it. I got a metal one from Ground Up. Didn't thiunk the odds were in my favor for a plastic one. What was on GMs' mind? Patton you got a voice in this matter?
AL
Al Graaf is offline
Old February 5th, 2012, 05:18 PM
The plastic ones were just plastic.
The metal ones were the standard dipped semi-flat black. If it doesn't have runs, it's not authentic .
MDchanic is offline
Old February 5th, 2012, 06:49 PM
Formerly "Shimmer"
Al Graaf's Avatar
Thanks for the insight Eric. Will dip it this week
Al Graaf is offline
Old February 5th, 2012, 07:00 PM
Yeah - I'm not sure where I read this, but the painting technique used at the factory was to pour some paint into a drum full of water. The paint would float in a layer on top, and they would dip the parts in. The thin layer of paint would coat the parts evenly (but perhaps not perfectly, as we know), with minimal excess, but would leave a few small runs.
MDchanic is offline
Old February 8th, 2012, 10:11 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
My 72 Olds had a plastic one, but my 72 Buick had a metal one.
J-(Chicago) is offline
Old February 8th, 2012, 10:32 AM
70Post's Avatar
I think the 1970 cars (and thus likely earlier as well) came originally with a metal cover as that's what I've seen on some "known original" type examples. After that, the math gets "fuzzy"......
>Don't know if production line changed to plastic sometime b/n '70 and '72, if it was a plant specific deal, brand specific deal or what (I have a '72 Buick that has a metal one but don't know the history of that part of the car as well).
>Or....possibly they were all metal for our cars and then GM changed the replacement, parts counter pieces to plastic at some point....that's what the repro places have sold for some time.
Maybe the design/material change was to give the part some slight flexibility to ease removal and installation...the metal ones frequently seem to hit/rub the D side exhaust pipe when you pull them off and install them. You can give them a good whack and get them to go on but that would have scratched the concours finish the factory had on these parts!
Pics below of a metal cover recently took some damage out of.
70Post is offline
OLD SKL 69
December 9th, 2012 07:24 PM
Pacecar
August 8th, 2012 04:40 AM
VikingBlue
June 4th, 2010 03:07 AM
JSGD1966
June 14th, 2009 03:54 PM
Quick Reply: Flywheel Inspection Cover
