Half-moon shifter linkage
Old August 7th, 2009, 11:49 AM
I used the search function and found some good info on the half-moon shifter linkage available on the late 60s B/C bodies with dual exhaust.
http://www.442.com/tech/tech.html
I was wondering... do I need one of these half-moon shifter linkages for my 1971 Olds 98? I was under the car yesterday installing downpipes and noticed that my shifter linkage doesn't have a bend in it. When I take the car to an exhaust shop should they be able to run dual exhaust down the driver's side of the car under the shifter linkage without any problems? I know the steering geometry changed in 1971 on the B/C body. I'm just not sure if this shifter linkage will cause problems on my car.
I already have the dual hump cross member so I don't have to worry about that.
Olds64 is online now
Old August 7th, 2009, 06:25 PM
66400's Avatar
That shift linkage only applies to 65-70 full size Olds with dual exhaust due to the steering box location. Henry
66400 is offline
Old August 10th, 2009, 05:39 AM
Thanks for the info Henry.
debfahey
October 4th, 2014 10:57 AM
ddx77
April 29th, 2010 12:20 AM
saved2az
November 23rd, 2009 07:26 PM
saved2az
Hurst/Olds
November 22nd, 2009 08:26 PM
Quick Reply: Half-moon shifter linkage
