Mounting an transmission cooler
Old June 6th, 2009, 05:06 PM
The Stickman's Avatar
I am trying to figure out the best way to locate some things. I have a new radiator and have an PermaCool oil cooler with fan. Now fitting the cooler in front of the radiator looks to be a mess as the way things are in there. So I was wondering can I mount the cooler on the backside(engine side) or would this make the cooler ineffective? Also can I mount it so the lines come in from the bottom rather than the side?
The Stickman is offline
Old June 6th, 2009, 06:34 PM
Top, bottom, side - the orientation of the cooler lines doesn't really matter. The fluid is pressurized and any trapped air will be pushed through. You do want to mount it in front, however. Are you talking about the Custom Cruiser? Mine has tons of room. I mounted the factory trans cooler from a D-body Fleetwood.
joe_padavano is offline
Old June 6th, 2009, 09:17 PM
Yea on the Custom Cruiser. There are those cross bars right in front of the A/C condenser and the cooler I have had flanges on it to bolt it down with rather than using push pins or ties. So I just don't know where to bolt it to.
My442
March 21st, 2018 06:20 AM
84oldsDelta88
March 30th, 2011 09:16 PM
dallasite21
September 29th, 2010 03:32 PM
#1CutlassSupreme
June 14th, 2009 08:45 AM
The Stickman
June 12th, 2009 03:34 AM
Quick Reply: Mounting an transmission cooler
