Proper use of the Hurst Dual Gate Shifter
What is the "correct" way to use the Hurst DGS? The previous owner didn't use it any and couldn't provide much help. In "normal" I have D, 2 and 1. D will shift automatically, and 2 and 1 just let me drive in first or second gear. So then what are the dual gate gears for? I also have a 1, 2 and 3 on that side. If I drop it in 1 on the DG side, romp on it, then upshift to 2 and 3...whats the difference between that and doing it on the "normal" side?
Today I romped on it in 2 on the dual gate side, then shifted to 3 by shoving the shifter all the way forward...and it went into neutral...at high RPM, which, uh, really impressed the wife.
It's a 1972 442 455/TH400.
The dual gates allow you NOT go into reverse. It should stop in the gear you select after slapping it. Perhaps your stops are worn, it should'nt go into nuetral like you describe.
Anyways, its often called a "his and hers" too. Allows for you to be more spirited in your driving on "his" side.
You start with the lever in the RH gate and all the way back. Launch the car. When you want to shift to second, slap the shifter diagonally towards the right front corner of the car. If it's working properly, you will go into second and stop. Release the lever and it springs into position for the next shift. When you want third, again slap diagonally towards the front right corner of the car. The shifter should stop in third gear.
ah64pilot
May 29th, 2012 03:04 AM
w-30dreamin
January 2nd, 2010 09:53 AM
