Slim Jim
I got mine from Ross Racing in Ohio ,heres some post to look at https://classicoldsmobile.com/forums...lim-jim-17372/
https://classicoldsmobile.com/forums...2-olds-162113/ if you look up KQQLCAT they did a Ross Racing swap but to a 61 olds they said it was fairly easy . mine was done to a 62 olds very different and much harder . is not cheap but had no choice after 2 rebuilds on the slim jim could not get parts and nobody in my area know how to fix it , hope this helps
The frame is different which changes the installation, on the 62 you have to make a new crossmember ,believe me I found out the hard way , research it , I think there’s a 4 inch difference in the frames ,
Scott Allen
July 11th, 2013 04:16 PM
