slim jim replacement
Old August 25th, 2007, 04:20 PM
airbagged 63 98
GeneS12320's Avatar
I have a 63 98 with a 394 and slim jim trans. I have always been unhappy with the trans. I am going to do the trans adapter and a TH350 or a 700R4. I am leaning towards the 700R4. Has anyone done this swap? Does anyone have any comments of suggestions?
GeneS12320 is offline
Old September 14th, 2007, 09:03 PM
Natas's Avatar
Gene,
I just did a swap in my 62. But I went with a 200-4R because it was a smaller compact design. But the stock 200-R4 probly can't handle the weight of the car. Mine is GearStar built (beyond stock for over 300+hp) with a Bendtsen's Trans Adapter. It all bolted together smooth. I then had to cut my transmission tunnel out to get it in the car. I did a standard cross member on the transmission and for my motormount I uses the stock crossmember (Shimmed down) and made new mounts with standard GM trans mounts and some well crafted angle iron. Those were attached to two bolts that went through the adapter and into the block. I haven't got a drive shaft in it yet. But I can't to see how many MPG I through down.
Natas is offline
Old September 15th, 2007, 06:46 AM
Here is an older thread on a similar subject. I have a 64 98 with a Slim Jim and it is a piece of junk. I am considering replacing the engine and transmission. Natas, about how much did it run you to replace the tranny?
https://classicoldsmobile.com/forums...94-1962-a.html
Olds64 is offline
Old September 28th, 2007, 02:31 PM
Natas's Avatar
Alot, but it is a performance transmission. Junk yard trans can be had for cheap.
Natas is offline
GeneS12320
April 28th, 2008 06:39 AM
exmoparluver
March 31st, 2008 03:08 PM
RatRod
March 22nd, 2007 08:17 PM
bjtstarfire
Drivetrain/Differentials
December 6th, 2006 09:56 AM
Quick Reply: slim jim replacement
