Switch Pitch TH400 switch
Old February 18th, 2021, 07:16 PM
Restorer
425HP409's Avatar
I have checked the solenoids in my transmission and they click with voltage, but I have no electric kickdown and wonder if the switch pitch is working. Is the switch repairable, or does anyone have a known good one?
425HP409 is offline
Old February 19th, 2021, 01:39 AM
Vista67's Avatar
Recent post here for big cars but switch is same.
https://classicoldsmobile.com/forums...vicing-149216/
Vista67 is offline
Old February 19th, 2021, 08:05 AM
edzolz's Avatar
Do you get power from the pedal switch? Noted in above post. Maybe the contacts inside are burnt or worn.
edzolz is offline
Old February 19th, 2021, 11:15 AM
Like what Ed said. I think you should, off the top of my head, get no power to the kickdown until floored, and get power at part throttle only to the switch pitch. There's three contacts on the armature, one is ign power in and the other two are the two outputs mentioned.
Koda is offline
Old February 19th, 2021, 11:29 AM
When you say "they click with voltage", does that mean you can hear them click when someone presses on the accelerator, or did you just jumper 12v to the solenoid terminals on the side of the trans? If they click with the accelerator (with the key in RUN, obviously), then the problem is internal to the trans. Could be the orifice in the solenoid is plugged, or it could be something internal to the trans. FYI, the way both of these solenoids work is that energizing the solenoid opens a vent hole in the hydraulic circuit that vents pressure to move the associated valve and activate the function. If the orifice in the solenoid is plugged, the pressure won't vent and you won't get stator vane movement or kickdown. Of course, if the valves are sticking in the throttle body, the result of no function is the same.
If you simply jumpered 12v to the terminals, then do you know the switch is providing 12v to the trans? Check for voltage at the connector when you step on the gas. If none, trace the circuit to figure out why.
joe_padavano is offline
Old February 19th, 2021, 05:13 PM
Restorer
425HP409's Avatar
Thanks for the info....
425HP409 is offline
MBOlds98
February 10th, 2021 06:37 PM
edzolz
January 25th, 2020 06:46 PM
CroixDad
March 25th, 2013 11:14 AM
mugzilla
Drivetrain/Differentials
November 19th, 2012 05:30 PM
AZ455
November 27th, 2011 08:35 AM
Quick Reply: Switch Pitch TH400 switch
