t-5 swap
t-5 swap
Has anyone swapped a mustang T-5 into your Olds? I have an 86 T-5 that I am planning to rebuild with a 2:90 1st gear. I have built all of the adapters necessary to mate it to the bellhousing. Any info good or bad will help.
Scott
Scott
try this thread
have a look here, richard has made considerable upgrades including a tranny swap, hope it helps
https://classicoldsmobile.com/forums...her-while.html
Keep in mind that the only engine that Olds ever deemed weak enough to not frag the T5 was the pavement-ripping 260. That trans was marginal behind a 305 Chevy or 302 Ford.
The cool thing is that the conversion is not too invasive and should the thing implode on me, swapping back to the Muncie would be a Saturday afternoon event. I sold my Type O posi for $1200.00, planing on installing a Mosier 9" rear end, I understand that these are bullet proof. I am thinking 3.30 series gears, with a 2.90 1st and an overdrive this thing should be a blast around town and on the highways.
'69CutlassVert'
August 25th, 2011 07:19 AM
