TH 400 trans locked
Old October 15th, 2008, 05:39 PM
hussy250f's Avatar
TH 400 trans locked
I had a 400 trans in my garage for a few years now and I am going to swap it with friend for a 700r4 with a bad case of cooked clutches for another project.
Problem is the 400 is stuck in what I assume is forward gears no matter where the selector shaft is positioned other than PARK.
The output shaft will only spin in 1 direction in any gear including neutral. The PARK position seems OK.
The trans sat for a few years in a garage, but was working fine when removed from the previous vehicle.
It makes a definite mechanical "bottoming" noise when you attempt to spin it the other way.
Maybe just stuck clutches or a band from sitting?
Thanks for any input.
hussy250f is offline
Old October 16th, 2008, 08:01 AM
If you've checked all of the obvious stuff (linkage, fluid level, etc.), I would say that you have an internal problem. The TH 400 uses a band to hold the ring of the sun and planetary gear set for reverse. Perhaps this band isn't engaging or is bad.
Olds64 is offline
Old October 16th, 2008, 02:54 PM
Junior Member
88 coupe's Avatar
Originally Posted by Olds64
........ linkage, fluid level, etc ........
Hard to do, when the trans is not in the car.
........ Perhaps this band isn't engaging ........
Not possible for that to happen without pressure in the system. Pressure, that is supplied by the pump when it is turned by the engine.
I see one, or both, of the sprague (one way) clutches as a possibility.
Talk to your local trans rebuilder to find out for sure.
Norm
88 coupe is offline
Old October 16th, 2008, 03:13 PM
A very high possibility. Alternatively, moisture (condensation or worse) has gotten inside the case and rusted parts together. Either way, the trans needs to come apart.
For complete correctness, it's a sprag clutch.
joe_padavano is offline
Old October 16th, 2008, 03:48 PM
Junior Member
88 coupe's Avatar
........ it's a sprag clutch.
Yes it is. My spalshikr should have caught that.
Norm
88 coupe is offline
Old October 19th, 2008, 06:05 PM
hussy250f's Avatar
Thanks for the suggestions, I'm thinking the forward or intermediate clutch is frozen since the output shaft does turn in 1 direction.
I guess I'll be tearing the trans down for an exploratory looksie.
Thanks again guys.
Old November 10th, 2008, 01:27 AM
RoaringRelic's Avatar
When you say "spin" do you mean turn freely by hand? It is normal for a turbo 400 to turn in one direction easily and the other very diffucult. This is because the reaction carrier is fighting with the low sprag, low roller after '70. If you have the transmission output yoke handy it will turn both ways but one will be harder.
RoaringRelic is offline
Muskrat
Alero
15
January 24th, 2010 08:48 PM
88 coupe
July 6th, 2009 11:15 PM
Warhead
July 4th, 2009 09:34 PM
Tangovino
Brakes/Hydraulic Systems
18
May 27th, 2009 02:38 PM
ragtop442
April 3rd, 2008 06:48 PM
Quick Reply: TH 400 trans locked
