TH400 leaking from lower coolant line
Another day another leak. Today's leak is on the lower transmission coolant line. It only leaks while the car is running and leaks about a drop every minute. I've heard online it could be an o-ring of sorts? Anyone have any ideas on this? Also is thread sealer a viable option on this? Thanks!
Don't just clean, inspect as well. When I bought my car the previous owner had installed copper lines. It leaked about a drip a minute, like yours. I thought I was smart to tighten the nut an eighth turn. When I started it up again, there was a geiser. Turns out the flare on the copper line was split; tightening made it worse, not better. Hope you have better luck. And if you have copper lines, replace them with steel as the factory intended.
Someone may have made single flares on your lines as opposed to double inverted flares. The double flare is thicker, no sealer needed.
70Cutlass_408
July 30th, 2011 02:50 PM
