TH400 Torque Converter
Old March 9th, 2022, 05:39 AM
brotherGood's Avatar
For anyone who hasn't been following along, short story is in I'm in the process of rebuilding my original 400G block out of my '69 442. In discussions with @cutlassefi it was determined I need to look for a converter that has a stall of 2600-2800.
I have multiple emails out to the top of my head converter companies (TCI, Hughes, Hays, B&M)..and so far TCI is the only one to respond thus far with either a Breakaway at 2400-2600 stall, or another one (haven't looked up the Part#) that stalls at 2600-2700..but was warned it was almost triple the cost.
I guess, first question would be what size do I need (9", 10", 12") and second, does anyone have any suggestions knowing what stall range I've been advised to look at?
Thanks in advance.
brotherGood is offline
Old March 9th, 2022, 08:32 AM
..just heard back from Hughes, they're suggesting the GM20-HD at 2,000 stall. They followed up with this: "The reason for the slightly lower stall is that the new converters are built on a smaller diameter core (10.5" versus 12") so they react different to big blocks with good TQ."
I mean, it makes sense..but I also know little about all of this.
Old March 9th, 2022, 08:42 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
10" is overkill IMO. 12" is fine TCI, Hughes, Coan, B&M all good. Strangely I no longer see 12" converters listed?
The chart is snipped out of Jegs under the TCI brand. Note big & small block columns.
droldsmorland is offline
Old March 9th, 2022, 10:27 AM
I'm not sure where I read it, but the 12" cores are very hard to come by so they just went to 10".
That being said, a 10" breakaway would be ample, based on the idea that the smaller size can actually run more efficiently at the lower stall...correct?
Old March 9th, 2022, 12:00 PM
I remember reading that as well. I think it was in a torque converter thread where it was also said the BPO threaded lug style converters weren't available any more, and the converter companies were using the cores with ears that use the bolt/nut setup instead.
Fun71 is offline
Old March 9th, 2022, 09:27 PM
I built a 400 trans for a motor home about 6 months ago, TransStar won’t even sell a stock converter without a core. The stock 12-13 inch converter cores are getting scarce. Who would have thought that would happen? I’m sure everyone scrapping stock converters for years played no small part.
I recall reading somewhere the industry standard for rating converter stall speed is 300 lbs/ft of torque at a specific rpm (I dont remember what that speed is). If the engine makes more torque at that speed, the stall speed is higher, lower torque, lower stall speed. Vehicle weight and gear ratio plays a big part in stall speed also.
Converter science has come along way in the last 20 years. A good high stall converter won’t feel mushy at part throttle.
I’d call Hughes, Coan, ATI, whoever you prefer and get a converter recommendation.
matt69olds is offline
Old March 10th, 2022, 10:09 AM
Hughes has me at a 2,000 stall, which doesn't seem to line up with what the cam calls for. I've also sent a message to Coan (never had heard of them) so we'll see what they say.
Old March 10th, 2022, 11:58 AM
Your post above said Hughes stated the "2000 RPM" converter will actually stall higher than that behind a big block. I would believe them as they do this for a living and have a very good good reputation.
Fun71 is offline
Old March 10th, 2022, 12:12 PM
That's fair, I was just looking at the cam info as well, so that's what geared my train of thought.
Old March 10th, 2022, 09:49 PM
I worked at Coan 25 plus years ago, their stuff is top notch, as is ATI and Hughes. Dave Coan and Steve Grinder invented the internal hydraulic style transbrake for the Powerglide in 1971. Coan and ATI pretty much created the performance automatic transmission industry. Before they started building custom converters, the hot setup was to use a 6 cylinder or air cooled converter in your race car. Sure, it gave you the stall speed you wanted, but a converter designed for 100 hp won’t last long with 600hp!
The 2000rpm converter will probably go to 2400 behind a torquey engine.
Old March 11th, 2022, 02:00 AM
Is this due to the smaller case? In that regard, would the original TCI suggestion of their Breakaway at 2400-2600 stall be right?
Old March 11th, 2022, 09:07 AM
Coan just came back with an 11" Pro Street converter. No specs on it, or part number though.
Old March 15th, 2022, 05:43 AM
After a couple days' of dialogue via email with Todd @ Coan, I placed an order for their 2600-2800 Pro Street converter. Once they get back in stock, theyll ship it out. In the meantime, I've gotta go ahead and hook up a trans cooler (half expected to do so anyway)
Old March 18th, 2022, 04:44 PM
To my surprise, the converter came in today. Now to find a cooler...
Old March 18th, 2022, 05:35 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I bought one of these for my truck, a Dana Tru Cool. Well made, an interesting idea in design.
https://www.trucool.com/products/tru-cool-lpd
olds 307 and 403 is offline
shamusj
January 24th, 2022 09:48 AM
jpayne_80@hotmail.com
September 1st, 2017 07:19 AM
VinMichael
July 22nd, 2016 04:32 PM
Stevec
January 15th, 2015 11:44 AM
montvaleplace
April 8th, 2011 01:52 PM
Quick Reply: TH400 Torque Converter
