transmission leaks
Old April 11th, 2010, 03:53 PM
1973olds98's Avatar
transmission leaks
i recently pulled my motor out of my 1973 olds 98...I have the 455 now at my local machine shop being rebuilt...I noticed that my transmission is leaking when i was pulling the motor..the leak appears to be coming from the front as there was trans oil on the plastic bell housing cover...My question is when i go to autozone.com all the seals are stating except for hydomatic transmission...What transmission do i have in my car..I know its stock...Is it a th400 ,,What seals do i need?
1973olds98 is offline
Old April 11th, 2010, 07:17 PM
70 cutlass s's Avatar
You need the front pump seal part number 6712NA. I put on in every time I pull a engine out and don't have the transmission rebuilt.
70 cutlass s is offline
Old April 11th, 2010, 07:23 PM
GM Enthusiast
OLD SKL 69's Avatar
I agree with Andy. Just replaced my front pump seal. It was hard and brittle and not flexible at all. Which of course, explains why it was leaking all over the place.
OLD SKL 69 is offline
Dead Reckon
September 25th, 2014 09:33 AM
ShaunM
December 30th, 2011 01:46 PM
Eightupman
Body work
June 20th, 2009 08:31 AM
Satellitecentral
March 16th, 2009 07:34 AM
polcatt
November 19th, 2006 01:33 PM
Quick Reply: transmission leaks
