Transmission pan
Old January 17th, 2019, 12:57 PM
1972 Cutlass Town Sedan
skyhigh's Avatar
Transmission pan
Is this the right aftermarket transmission pan for my 350? on amazon it says doesn't fit a 72 cutlass, or any recommendations for an aftermarket pan. I do have a leak so I want to get a new pan since I need a gasket, and a pan with a plug would make life easier for future oil changes..thanks
Amazon Amazon
skyhigh is online now
Old January 17th, 2019, 01:29 PM
Every single TH350 ever made has the same 13 bolt trans pan bolt pattern. If it fits any TH350, it fits yours. On-line application catalogs are notoriously inaccurate, particularly with respect to Oldsmobiles. Do you really want one that deep with the fittings? I don't thing I paid that much for the whole transmission.
joe_padavano is offline
Old January 17th, 2019, 01:36 PM
skyhigh's Avatar
Well I wanted to use there gasket so I thought get there pan. Being Canadian its about 100 more than the US price lol, is there another pan you recommend Joe with a drain plug that will work with the Moroso gasket, I gladly get something else if you think its good..
Amazon Amazon
Old January 17th, 2019, 01:56 PM
For the most part, I just use stock steel pans. If you want aluminum for the thicker flange, there are a number of options in the $60-$120 range (yeah, those are US numbers, so figure 30% higher or so). Summit has about 30 different TH350 pans from stock to extra deep. Your Moroso is $212 US.
Old January 17th, 2019, 02:40 PM
skyhigh's Avatar
Thanks for the tip Joe, just looking at this now, after price into Canadian and shipping I will save over 100
https://www.summitracing.com/int/par...1000/overview/
paired with this
https://www.summitracing.com/int/par...g350/overview/
Old January 17th, 2019, 06:45 PM
Used 350 oil pans can be found literally everywhere. You might consider stopping by an auto salvage yard and/or a transmission shop.
Vintage Chief is offline
Old January 18th, 2019, 06:59 AM
I'm guessing he can find a used OEM pan bolted to the bottom of his current trans. I assume he's looking for an aftermarket pan with a drain plug.
Old January 18th, 2019, 11:34 AM
Ah. I was thinking his current pan had a hole (albeit leak) and I should have paid closer attention to the fact he did want an aftermarket.
Old January 19th, 2019, 12:52 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Do you really need a deep pan? The pan below worked fine for me. That gasket looks like the stock Mopar gaskets which well Summit and Moroso brands offer similar.
https://www.summitracing.com/int/parts/spe-5450/
olds 307 and 403 is online now
Old January 19th, 2019, 01:02 PM
That's a great looking pan; and, w/ a plug. Thanks for sharing.
Old January 19th, 2019, 03:14 PM
skyhigh's Avatar
Ok took your advice, went stock, but got alum, here what I ordered and it on the way, thanks everybody for you input, much appreciated, hope this fixs the leak, gotta watch the torque specs Cant wait to pick your guys brains about my wheel hop next, I will start a new thread when I'm ready to order some parts..
Pan:
https://www.summitracing.com/parts/sum-4338856
Gasket:
https://www.summitracing.com/parts/lub-llt-g350
Filter:
https://www.summitracing.com/parts/wix-58878
Old January 20th, 2019, 07:23 AM
https://www.summitracing.com/int/parts/sum-g3885b/ There is also a black pan, I like the idea of your aluminum pan. Let us know how that gasket works. One thing I did that helped these old trans seal was going tractor trans hydraulic fluid. Good luck.
Old June 24th, 2019, 02:49 PM
skyhigh's Avatar
Well the gasket is great, don't see any leaks from the pan gasket, the pan needed a little work to get it in, it didn't have the little bend like the old pan to get 2 bolts in by the tranny mount, so had to remove all the mount bolts, shim it back a little, wasn't easy due to old seized bolts, had to cut em, jack up the tranny a bit to get the last 2 bolts in. I still seem to be chasing a leak, I see drips coming off the black cover, any idea what I can try next, Its driving me crazy.
Old June 24th, 2019, 03:05 PM
[QUOTE=skyhigh;1181069...I see drips coming off the black cover...[/QUOTE]
I was following up to this point...what black cover?
Old June 24th, 2019, 03:07 PM
skyhigh's Avatar
the Flexplate cover I think, you need to remove the black cover to install the new pan..
Old June 24th, 2019, 03:09 PM
Ah, OK. The cover over the flexplate/torque converter. Is it transmission fluid or engine oil? Most/Often times it's engine oil seepage from the rear main (rope) bearing seal. Is it coming out the hole at the bottom of the cover? Identify if the oil is engine oil or trans oil first.
Old June 24th, 2019, 03:11 PM
Two other notorious areas are the oil filter mount assembly and possibly the O-Ring at the bottom of the distributor where the distributor sits. Gobs of oil or small drips on occasion?
Old June 24th, 2019, 03:20 PM
You can grab a small bottle of fluorescent/UV dye from any local auto parts store. Pour it into your engine oil and run the engine.
Remove the torque converter cover and clean the area thoroughly. Take vehicle for a short cruise. Visualize the area w/ a black light. The fluorescent/UV dye will demonstrate the trail of the oil.
Old June 24th, 2019, 03:31 PM
skyhigh's Avatar
It red fluid..tranny leak lol
Old June 24th, 2019, 03:36 PM
First things first. Any chance you happened to overfill the transmission w/ transmission fluid when you filled the transmission with new fluid? This is a prime suspect if you inadvertently overfilled the fluid. Checked your fluid level both HOT & COLD?
Old June 24th, 2019, 03:41 PM
skyhigh's Avatar
Yes i did overfill it lol..i only added 4 litres at first..i bought 10...thought i would put 4 in and run the motor..need more according to the dip stick so i added another litre and it was over
Old June 24th, 2019, 03:46 PM
I had my suspicion. OK. Run the engine 10 minutes. Check the transmission fluid. Ensure the transmission fluid is above the cold mark, but NOT above the HOT mark. The proper amount of fluid on a transmission at operating temperature should be as much as possible dead even between the COLD and HOT mark. Drain out some transmission fluid. You can use a siphon pump hose, or what I use is a large syringe attached to a long piece of clear tubing. It's a PITA pulling the syringe to suck out the trans fluid, but it beats dropping the pan! LOL Just ensure you get the fluid between the HOT & COLD mark. Once done drive it for several days - you'll probably be fine.
Old June 24th, 2019, 03:50 PM
skyhigh's Avatar
My new pan has a plug..might be easier...i will try that tomorrow. Thanks for the help..so where is the fluid coming from if it over
Old June 24th, 2019, 03:53 PM
Lucky You! Plugs are so much nicer. Just ensure you're below the HOT mark when the engine is at operating temperature. You might have a leak for a couple days until the previous foaming of the transmission fluid settles down from overfilling it. Drive it regularly for several days and check if the leak is still there. Chances are it will be gone.
Old June 28th, 2019, 12:59 PM
skyhigh's Avatar
Well taking the fluid the proper levels didn't stop the leak lol..so I had enough, brought it to the tranny shop for a free diag and he told me the accumulator seal is leaking and the shifter shaft seal, so it goes in next week for the fix, he didnt have the parts i guess, so looking forward to a dry driveway. Any tips on how to the stains out?
Old June 28th, 2019, 06:17 PM
Simple green or power purple. If it’s a concrete drive, use muratic acid.
Some of the early 350 had factory drain plugs. Typical GM, they eliminated the drain plug as a cost saving measure.
matt69olds is offline
defiant1
April 23rd, 2014 03:40 PM
brandon 455
March 29th, 2014 01:49 PM
RandyS
October 28th, 2013 11:57 AM
gearheads78
August 18th, 2011 08:27 PM
mmcilroy
April 30th, 2010 05:55 PM
Quick Reply: Transmission pan
