Transmission Tunnel Reshape
Old March 29th, 2014, 07:29 PM
Oldracerjones's Avatar
I need to increase the height of my trans tunnel for a 70 442 to ensure clearance of the driveshaft knuckle. Does anyone know of an aftermarket source for the new top of the tunnel or is purely a fabrication piece? Any help would be appreciated.
Oldracerjones is offline
Old March 29th, 2014, 07:59 PM
Are you changing transmissions?
oldcutlass is offline
Old March 29th, 2014, 08:19 PM
dc2x4drvr's Avatar
I modified my crossmember to better clear the trans yoke, after installing my 5 speed.
Are you swapping transmissions?
dc2x4drvr is offline
Old March 30th, 2014, 05:26 AM
RonFX's Avatar
trans tunnel hump
Guys:
In need the same thing to finish the floor in my 66 Cutlass, someone chopped up the hump years ago. I would rather use a new part rather than drag the generator to the salvage yard and cut out a donor piece, there is a yard that has 3 of them but they don't remove parts for you from vintage cars, you gotta do it yourself.
Thanks Ron
RonFX is offline
Old March 30th, 2014, 05:53 AM
dc2x4drvr's Avatar
Originally Posted by RonFX
Guys:
Thanks Ron
I think the only new tunnel would be part of a repro floor. Sounds like a job for a battery powered sawzall
Old March 30th, 2014, 11:48 AM
Not changing trans but since I bought it I've had issues with the drive shaft hitting the tunnel going over bumps, hard acceleration, etc. I fixed most of it with new springs and shocks but it will still hit with a couple people in the car or when getting into it. The PO has the tunnel pretty chopped up as it went from an auto to 4-speed. I figured I would cut the top off, build a reshaped tunnel just slightly higher than it is now but enough to give good clearance, then weld or rivet it back on.
The lower profile is great, with nothing below the exhaust pipes, afraid if I modify the trans crossmember it will stick out too low.
Old March 30th, 2014, 04:12 PM
X2 on the trans mount and also check motor mounts and body bushings.
Old March 30th, 2014, 04:27 PM
classicmuscle442's Avatar
Check manual, trans mount height for four speed shorter or could it be length of driveshaft causing noise.
classicmuscle442 is offline
patmills
Tech Editor's Desk
June 17th, 2015 09:36 AM
MikeManer
April 29th, 2014 07:39 AM
2blu442
December 16th, 2013 07:14 AM
37OldsCoupe
March 2nd, 2013 12:23 PM
Gwillett
January 3rd, 2007 08:31 AM
Quick Reply: Transmission Tunnel Reshape
