Turbo 350 Tranmission Live behind a 455
Old March 11th, 2014, 05:49 PM
78 omega 468's Avatar
What would need to be changed in a turbo 350 transmission to make it live behind a 455 with 466 hp and 500 torque? Will be street driven and occasionally taken to the strip for test and tune night. M/T 9" Street ET's 3:42 rear end.
78 omega 468 is offline
Old March 11th, 2014, 06:28 PM
Not much if the trans is in good condition. At the absolute minimum, install a shift kit, preferably one that uses a aftermarket pressure regulator spring. The Trans-Go shift kit, the B&M Transpak, and the TCI Trans-scat kit do. If your overhauling the trans, machine the direct clutch piston to allow installation of an added clutch and steel. A aftermarket intermediate sprag race would be a nice upgrade, but make sure you get a quality part! Some of the cheap aftermarket races are much harder (weaker) than stock, and will shatter. Trans-Go, Coan, etc all have good quality parts.
I helped coppercutlass a few weeks ago with his TH350 build, read that thread for some more build tips.
matt69olds is offline
quentinnw2
October 28th, 2013 02:06 AM
CHEV VAN
January 25th, 2010 07:51 AM
Liegekiller
May 30th, 2009 05:31 PM
bccsrc
July 23rd, 2008 01:22 PM
Quick Reply: Turbo 350 Tranmission Live behind a 455
