Whats the easiest trans swap for 67 C/S S.B ?
I may be wrong but ive done some reading on my question as i dont want to be a pain. My 67 C/S has a 330/320 100% stock & is nothing but a Sunday cruiser at best, my racing days are over. That being said, what is the easiest least aggrevating trans to install behind my motor ? ( Closest to bolt right up ) The 2 speed jetaway just wont cut it even just being a sunday driver. I have the switch pitch set up but dont want the hassle of yanking it & trying to find someone to go through it & hopefully know how to fix it. Id rather keep the stock trans in storage & find a trans to swap out as easy as possible. My limited research looks like the 200-4R, am I correct ? Is it 100% exact bolt up or are there a few hurdles ? Thank you.
Your car probably has a 3.07 differential ratio, which is too high of a speed for an overdrive transmission. You need at least a 3.42-3.73 for an overdrive to operate correctly. The car has worked great for 45 years with the 3.07 and a non overdrive transmission and that is what I would stay with. It will still cruise at 70 mph with no problems. The easiest transmission to install would be a TH350 or TH400. Either one will work great with your 330. A TH400 doesn't need any cable connected to your carburetor, whereas a TH350 really needs a kickdown cable connected to the bottom of the carburetor lever. this increases pressure to the transmission on moderate throttle and also enables "passing gear". Both use a vacuum modulator and the TH400 uses vacuum for moderate kickdown, and an electric switch for full throttle kickdown. I have a 67 442 with 3.07 diff ratio, and a 63 Impala with a 3.08 ratio, and they both cruise just fine. I am not interested in going 80-120 mph in an old car anymore, Been There, Done That
Sorry, gotta disagree. My 84 Custom Cruiser came from the factory with a 200-4r, 2.78 rear gears, a pavement ripping 140 HP 307, and probably an extra 700 lbs on that 67. Never a problem in OD. I'll also point out that the 2.74:1 first gear in the 200-4R will really wake up the car as compared to the 1.76:1 first gear in the Junkaway.
Charles
Joe, I know that your 84 did ok with the tall gears, but I believe that was because the engine was tuned (cam, compression, carb, valves etc) from the factory to do that. IMO, the older cars don't work as well due to the fact that were tuned to run at higher RPMs on the hiway and with a 3.07 ratio and overdrive, the net ratio would be 2.15. If I was contracted to repair his transmission, I would put in a 350, which has a 2.48 first gear and he would love driving it without spending a great deal of money. This is just my opinion.
Charles
Charles
Charles
Charles
Charles
Charles
I have a hard time wrapping my head around the concept that a stock VIN Y 307 is capable of outperforming a 330 at under ANY conditions.
Just sayin'...
The reason the Olds manifolds appear lower and wider is the design of the heads. Olds used a more sharply curved exhaust port design that exits the heads lower than on a Chevy. This makes spark plug access much easier but is unfortunately the main reason why stock Olds heads flow more poorly than others. It's also why Edelbrock was able to improve exhaust flow in their aftermarket heads by making the ports SMALLER than stock - but straighter.
Uh, the wider bank angle refers to the lifters and is totally inside the block. The cylinders are at the same 90 degree bank angle as any normal V8 (yes, I said "normal", lest someone point out the second-gen SHO motor as an example...).
I'm going to swap in a 3.23 or 3.42 in my 85, it's stock with a 2.78 atm. The 307 is for sure a low end power motor, so putting a shorter gear in it with the 2004R trans should get it off the line a bit faster. Go with a 3.08 if you want to keep decent MPG, really you could go up to 3.42 and stay decent on the MPG.
RandyS
Drivetrain/Differentials
October 3rd, 2014 04:21 AM
1Fastolds
Ninety-Eight
June 9th, 2014 09:12 PM
