Where's my bell housing?
Old November 17th, 2008, 06:34 AM
1972 Cutlass 455
silverriff's Avatar
Question Where's my bell housing?
O.k., stupid question.... I do not have a bell housing on my 1972 Cutlass 455. The fly wheel/torque converter are all out in the open. Is that normal? Did someone just take it off and not put it back on? And if its not on there, should it be? HELP I'm scared!!
silverriff is offline
Old November 17th, 2008, 06:44 AM
Registered
Bluevista's Avatar
If nobody answers before me, I think the cover is missing on the bottom.
Allan
To be more specific the flywheel, clutch, or converter housing cover.
I was watching the Barrett-Jackson auction and more than a few big buck cars had them missing too.
Bluevista is offline
Old November 17th, 2008, 07:29 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Yeah, sounds like your inspection plate is missing.
http://images.google.com/imgres?imgu...3Doff%26sa%3DG
J-(Chicago) is offline
Old November 17th, 2008, 11:53 AM
csstrux's Avatar
All you are missing is a tin plate that is called a dust shield. The housing is cast as a single unit with the body of the trans. I'm not sure but would assume any dust shield off an Olds of similar vintage will bolt up in place. But all in all it probably isn't necessary. I have had countless cars over the years that have not had them on without a problem. Keep in mind I used to run A LOT of beaters.
csstrux is offline
Old November 17th, 2008, 06:29 PM
citcapp's Avatar
Based on your information You do not have a transmission all you have is the flywheel and torque convertor. In order to have a Bell housing you would have a stick transmission with a flywheel, clutch plate, and a pressure plate
citcapp is offline
jensenracing77
December 20th, 2022 12:37 PM
brandon reynolds
March 16th, 2010 07:02 PM
mono-plane
October 15th, 2009 04:40 PM
dan2286
July 26th, 2008 05:00 PM
ozoneblue
August 21st, 2007 05:59 PM
Quick Reply: Where's my bell housing?
