Will a 67 Jetway tranny fit on a 1969 455?
Will a 1967 Cutlass jetway transmission bolt up to a 1969 455? Got a friend who's curious in getting a 455 for his Cutlass & it has a stock jetway. Thanks for any info.
Yes it will bolt up just fine.
If you plan on using the Switch Pitch you'll have to rig up something to make it work or it will be in low stall at all times.
I think the friend wants to put the 455 in a 67.
If the 67 in question is a Jetaway car, the throttle switch should already be there and can still be used with the 455. Might have to tweak the adjustment a little bit.
