69 W30 Converter Stall Speed?
Old May 16th, 2012, 09:24 AM
Billb442's Avatar
I have a 69 W30 that when put into gear seems to really lurch forward (or back) and will sometimes stall. The idle is set to 950rpm which I think is correct for a W30? So I am just curious if the W30's came with a different stall converter than a normal 400 engine?
Billb442 is offline
Old May 22nd, 2012, 04:43 PM
442Harv's Avatar
Yes it should be a higher stall. Try lowering your RPMs, If it still clunks hard when you put it in gear, and wants to go, you probably have the wrong convertor.My sons 68 W30was like that when he bought it. It as no fun to put it in gear.
442Harv is offline
johnnyjaws
October 26th, 2014 06:57 AM
oldspower_68
March 20th, 2012 08:43 PM
455Gbody
September 8th, 2009 11:18 AM
455Gbody
September 1st, 2009 02:46 AM
Pghstarsky
October 29th, 2007 08:53 AM
Quick Reply: 69 W30 Converter Stall Speed?
