Kickdown switch on 71 442...
Old September 29th, 2023, 03:45 PM
Tancuda's Avatar
Hi all,
Can you tell me if something is wrong with that kickdown switch. I have a small video but I can't upload it.
The pedal travel about 1"+ before touching the switch....and there's a rubber hose on it too.
Tancuda is offline
Old September 29th, 2023, 07:59 PM
Someone put the rubber hose over the switch plunger to get the kickdown to come in a little sooner.
matt69olds is offline
Old October 3rd, 2023, 03:08 AM
Tancuda's Avatar
Thanks, I'll just check if I have power on these wires.
Tancuda is offline
Old October 3rd, 2023, 04:55 PM
Tancuda's Avatar
Ok, there's power on one wire with ignition ON, and if I move the switch all the way, the second wire as power, so I think it's good,
but if I floor the pedal, no way that switch is going all the way, so no power on the second wire.... could it be a wrong accelerator cable ?
There's a 1980 rochester on it right now, could it be that the throttle is not located where it should be? Or is the kickdown switch adjustable ?
Thanks for your help
Tancuda is offline
Old February 2nd, 2024, 09:20 AM
Tancuda's Avatar
Here'a picture from Joe, if I compare to mine (Post #1), I see that my rod is rubbing on the switch, what could do this ?
Tancuda is offline
Old February 2nd, 2024, 09:43 AM
Loaded68W34's Avatar
It looks like someone bent your switch bracket down and toward the pedal to make room for that bundle of wires coming through the firewall. You will need to straighten the bracket for it to work properly and possible re-route/ remove the wires and conduit coming through the firewall.
Loaded68W34 is offline
Old February 2nd, 2024, 10:11 AM
Tancuda's Avatar
Thanks for the reply, ok so the bracket should line up a bit with that bundle, I'll give it a look when my friend bring me the car,
thanks again
Tancuda is offline
Old April 21st, 2024, 10:27 AM
Tancuda's Avatar
Ok i did bent the switch a little and looks ok. Now can somebody tell me (see pic) if the travel of the switch looks ok, I have continuity when about 3/8 inch to full extention of the switch.
Tancuda is offline
timothypaul
October 19th, 2021 07:20 PM
nracobraguy
October 2nd, 2021 03:23 PM
tonka
April 16th, 2020 07:08 AM
AZ455
November 27th, 2011 08:35 AM
DRXOLDS
August 24th, 2011 10:47 PM
Quick Reply: Kickdown switch on 71 442...
