leaking speedo cable at trans
Old December 8th, 2023, 10:39 AM
ej69's Avatar
1969 cutlass
i am getting a drip out of the end of the speedo cable housing that screws into the speedo gear housing cover on trans (th350). i replaced the gear housing 5 yrs ago when swapped out speedo gears in trans. Fluid is dripping out of female housing end of cable. Would a worn speedo shaft not be making a good seal with small o ring in the housing? Like i stated, the speedo gear housing and seals are only 5 yrs old. Speedo cable is original.
thanks eric
ej69 is offline
Old December 8th, 2023, 01:11 PM
The only way to know is to pull the housing and driven gear and inspect them. At that point, you MIGHTASWELL replace the seals on the housing when it's out.
joe_padavano is offline
Old December 8th, 2023, 02:04 PM
Sugar Bear's Avatar
Agree with replace the seals and yes it can be a worn driven speedo gear. If available I'd replace the both the seals and the driven gear.
BTW, that undercarriage looks quite respectable! Did you finish it?
Sugar Bear is offline
Old December 8th, 2023, 02:14 PM
Burd's Avatar
Burd is offline
Old December 8th, 2023, 02:55 PM
ej69's Avatar
Figure replacing seals, just disappointed only lasted 5 yrs from repair.
yes I did restoration around 10-12yrs ago.
ej69 is offline
bigron111
September 22nd, 2018 06:39 PM
stephenca118
August 13th, 2017 08:06 AM
Mike_ATX
October 28th, 2014 07:56 AM
OldsCutlass70
May 2nd, 2013 09:29 AM
ej69
March 22nd, 2010 03:28 PM
Quick Reply: leaking speedo cable at trans
