Need help on a duel gate shift cable
I bought a new shift cable from OPGI that is 30-1/2" long for my 1971 442 duel gate it seems to be to short, I do not have the old cable to compare, any ides I need help.
Dale, are you having problems getting in park or 1st gear? Your bracket at the trans might be the problem. Need to grind the slot in the bracket a little longer. I had to do this also.
Check this thread: https://classicoldsmobile.com/forums...r-bracket.html
