Rear End Swap for a 1978 Delta 88
Old June 27th, 2023, 03:18 PM
78-88's Avatar
I have a 1978 Delta 88 Royale coupe. Last year we took out the stock Rocket 350 and the Turbo 350 trans, replacing them with a built Olds 455 marine block with K-heads and a Turbo 400. The motor puts out about 400 HP and over 500 lb. ft. of torque. But, with the stock open differential and 2.41 gears, you can't feel the power coming off the line. I know the gearing was for MPG, but I don't care about that. I'm thinking of going with a posi and 3.42 gears. Are there options to swap in a used posi rear end (e.g., '95 Impala SS or same year Roadmaster)? Any other thoughts would be appreciated.
Thanks, Mike
78-88 is offline
Old June 28th, 2023, 07:28 AM
newmexguy's Avatar
Believe that rear end is the "corporate" 8.5 in unit. There should be an adequate selection of aftermarket ring and pinion sets available.
newmexguy is offline
Old June 28th, 2023, 08:10 AM
Hammerdrop's Avatar
That 95 Impala used wheels with a 5" diameter bolt pattern, so you would have to have the axles redrilled and center machined down too.
Hammerdrop is offline
Reese Jacobs
December 8th, 2019 05:03 PM
71 delta88guy
November 18th, 2014 09:44 AM
Movesomething48
February 26th, 2014 04:14 PM
80delta350
Drivetrain/Differentials
September 3rd, 2009 04:45 PM
Edveen
February 28th, 2007 11:12 AM
Quick Reply: Rear End Swap for a 1978 Delta 88
