Which Speedo Adapter?
Old November 12th, 2023, 08:38 AM
Magna86's Avatar
Alright the 66 is running and driving finally :-) but the speedometer is way off. It's running 25mph faster than I'm going based on GPS speedo app. So when I'm going 65 it says I'm going 90. The car is running a 700R4 with a green driven gear and and orange/red drive gear. 3.90 gears out back and 27" tires. Based on what I've found there are no gear combo that will work. So it looks like I need an adapter but which one do I need to slow it down and read accurately or pretty close.
Magna86 is offline
Old November 12th, 2023, 12:22 PM
olds_freak's Avatar
You'd need to change your drive gear to the gray one which has 15 teeth compared to your red one which has 17. Then you'll need either a 43 or 44 tooth driven gear. Either of those will get you close as it's calling for a 43.65 tooth driven gear.
olds_freak is offline
Minnesotajeff
February 4th, 2019 08:58 AM
ostie13
May 14th, 2016 08:05 AM
Redbud40
July 1st, 2014 05:28 AM
tmaleck
September 23rd, 2013 01:47 PM
delta254
Drivetrain/Differentials
October 18th, 2012 10:11 PM
Quick Reply: Which Speedo Adapter?
