Torque converter stall olds 98
So I got a good deal on an ‘72 olds 350 and I swapped it into my 84 olds 98 coupe it’s got 7 a heads and a cam but unfortunately I will never know the specs of the cam because the guy I bought the motor from didn’t remember. The motor came with a th350 that had a 2500 stall but I decided to get my 200r4 beefed up and I got a 2500 stall for it since that’s what the other trans had on it. The motor runs great but when I drove the car it was way up in the rpm’s and was sluggish. The trans shifted when it was supposed to but the car was super doggy. The rear end is stock so I was thinking maybe 2500 stall is too much for the stock gearing so I pulled the trans back down to go back to a stock stall but my understanding of torque converter stall is pretty limited so I thought I would inquire here before I go any further
I have a 3.23 rear end out of a 90’s caprice that eventually I’m gonna put in the car but I’m just tryin to get the car on the road right now as it’s already summer
Did you happen to look at the splines on the stator support tube on the transmission pump? For some stupid reason, GM didn’t heat treat those. I would not be the least bit surprised if you find the stripped. No splines on the stator tube, the sprag in the converter has nothing to hold, resulting in really low stall speeed and doggy performance.
The stator tube is pretty easy to replace, but it does require minor transmission disassembly.
FYI, my car has a Hughes Performance 2500 RPM converter and it worked perfectly fine when I had a 2.56 gear rearend under the car while I was rebuilding the 3.23 rear. Drove like factory with no issues at all, city and highway driving.
maybe my tv cable wasn’t adjusted right or something then but the trans shifted at the correct speeds but it was hard to pull away from a stop and the car was real doggy
I think my tv cable isn’t adjusted right bc I put a stock stall speed converter in the trans and it more or less drove the same
I bought these tv cable brackets that are supposed to work with my carb set up but when I pull the cable back and then move the carb lever to wot to allow the cable to self adjust it’s way off from where it should be. I pulled the cable back a couple clicks and it drives a little better but I’m only going around the block cause I don’t wanna mess up the trans
the tv cable is new from when they rebuilt the trans
