Transmission cooling lines with headers
Old April 12th, 2024, 05:54 AM
rfpowerdude's Avatar
What have people done for transmission cooling lines when using headers? 1970 Cutlass S with TH350. It looks like the transmission lines would normally go outside of the exhaust manifold on the frame, whereas with exhaust headers, the header is in the way. Maybe just hand bend them into submission? I have new replacement lines that would work perfectly with exhaust manifolds. Headers, not so much.
rfpowerdude is online now
Old April 12th, 2024, 06:01 AM
I had some hydraulic hoses made to run then up and over the inner fender along side the heater hoses.
oldcutlass is online now
Old April 12th, 2024, 06:06 AM
Yes, it seems that flexible hoses would be a great way to make custom routing for the lines. Since they are not under a lot of pressure, almost anything would be better than hard lines all the way back. Maybe some –6 AN to hardline adapters and braided lines might be nice.
Old April 12th, 2024, 06:11 AM
This is what I did.
Old April 12th, 2024, 06:17 AM
Very nice! Mine is factory AC so I will have to come up with a routing scheme.
Old April 12th, 2024, 06:54 AM
4speed455's Avatar
I used lines for a 72 on my 70 and made a few bends to move them out of the way of the headers and the suspension. The 72 radiator has the top line port much lower then the 70, this helped keep the lines up out of the way.
https://classicoldsmobile.com/forums...cement-166624/
4speed455 is online now
Old April 12th, 2024, 08:29 AM
^^^This. I've never had a problem that a few minor tweaks didn't resolve. I'm not a fan of rubber or AN lines for trans cooling.
joe_padavano is online now
Old April 12th, 2024, 09:00 AM
Mine have been on there since 2011 with no issues. Most aux trans coolers use rubber lines.
Old April 12th, 2024, 09:07 AM
Lots of aftermarket parts take the easy way out. When you are selling a one-size-fits-all cooler, it's kind of difficult to provide pre-bent hard lines. That doesn't mean it's the best answer. The factory RPO M55 aux trans cooler used hard lines. I find hard lines much easier to route, cleaner looking, and definitely less prone to damage.
Old April 12th, 2024, 09:32 AM
Rodney
cdrod's Avatar
I made and flared my own lines for my '72 442 convertible project. I wrapped both lines in heat shrink tubing followed by an outer layer of heat shield material where they pass close to the header tubes.
Rodney
cdrod is offline
Old April 12th, 2024, 12:23 PM
bccan's Avatar
I ran them along the oil pan rail. 1 or 2 clamps using pan bolts, out the front and to the radiator. They’re visible under regulator, heading past idler arm and past the lower rad hose drain clamp jungle..
bccan is online now
Old April 12th, 2024, 01:17 PM
On my 70 and 71 (both with 350s and AC), I simply bent the factory lines as needed to clear the headers.
Fun71 is online now
Dpj54
November 16th, 2020 06:35 AM
Fletchmo72
July 26th, 2018 04:49 PM
my71olds
July 13th, 2017 09:57 PM
ralsy
January 5th, 2011 05:10 PM
GothamCity
October 25th, 2007 06:10 PM
Quick Reply: Transmission cooling lines with headers
