Wanted posi for 67 cutlass
I asked a similar question a while ago. Here was a good response I got.
The 66-72 Cutlass/442 have the same width rear as the 68-72 Chevelle. The 64-65 Cutlass/442 have the same width rear as the 64-67 Chevelle.
Buick & Pontiac followed suit with Oldsmobile,so the 66-72 Skylark/GS,and 66-72 Lemans/GTO have the same width rear as the 66-72 Cutlass/442.
Anything with highway gears & no posi can be had for cheap,$100.00 or less.If you get a rear from a Chevelle,it will likely have the 1310 u-joint yoke,so you would need a different u-joint to make it work.
nj_cutlass72
November 20th, 2019 09:11 PM
69OldsCutlassS
Drivetrain/Differentials
September 9th, 2009 01:05 PM
buzzbomb
January 6th, 2008 09:51 PM
