What Torque Converter To Buy??? Hughes?
Old June 16th, 2019, 01:19 PM
kiloman_11's Avatar
Need to replace my torque converter of unknown make and stall on my 1970 Cutlass S 350 4bbl/TH350 car. Mild cam, 256 gears, cross country car/daily driver. I am looking at the Hughes converters since I see they are supposed to run cooler and heat/longevity is a concern. Any experience with the Hughes GM20 or GM25 converters? Is a 2000 Stall going to be ideal for a highway gear 350 car? Any help and advice is welcome I gotta get this thing put together soon!
kiloman_11 is offline
Old June 16th, 2019, 02:44 PM
I have the GM25 in my car and I really like it. If you plan to keep the 2.56 gears then the 2000 RPM converter should work well. Back in the 80s I had a 1970 Supreme with 2.56 gears, a mild cam (.432" lift, 204º duration), and a 2000 RPM converter that worked very well together.
Fun71 is online now
Old June 16th, 2019, 04:07 PM
kiloman_11's Avatar
I see hughes says the stall rpm rating is for fresh big blocks and that small blocks will vary 300-500 rpm lower. What would the GM25 be like in my 350? would it be rough to drive around town, idling in gear and all?
Old June 16th, 2019, 04:33 PM
Mine stalls near 2400 RPM based on watching the tach while going WOT from a dead stop, but that is with the 3.23 rear gears and a 217/221 cam.
A few years ago I had the 2.56 rear on the car for a few months and the 2500 RPM converter worked well even with that gear ratio. It basically seemed how I recall the factory converter operating during around town, light throttle driving. Regular feeling shift points when leaving from a stop and no excessive slippage when cruising at 35-40 MPH.
Fun71 is online now
Old June 19th, 2019, 06:29 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Nice real world experience above, 2400 is a nice flash point, you must be making decent torque. My discussion with Hughes were it would stall lower, you will probably be closer to 2000 with your probably 204/214 cam with their 2500 stall. I bet your current stall is something like 1500 flash stall which blows.
olds 307 and 403 is offline
Old June 19th, 2019, 10:16 AM
kiloman_11's Avatar
Would I see any difference between the two while highway cruising? Between 70-110mph? It's a non-lockup as well. This is all really helpful
Fletchmo72
July 6th, 2018 08:34 PM
HeavyOlds
August 8th, 2017 04:36 PM
aribera94
December 11th, 2014 11:46 AM
jerseyjoe
July 1st, 2013 06:50 PM
oldspower_68
March 20th, 2012 08:43 PM
Quick Reply: What Torque Converter To Buy??? Hughes?
