1948 Oldsmobile radiator leak
Old July 17th, 2015, 11:33 AM
Jims48's Avatar
Just sprung a leak in my radiator. Looks like it is coming from near the top. I have to take the cowl off to verify. In the meantime, does anyone know where I can get a replacement or have this one rebuilt. The car is a street rod so I don't necessarily need original, just bolt up compatible. Any info would be appreciated
Jims48 is offline
Old July 17th, 2015, 12:35 PM
See if there is a local radiator repair shop in your area.
oldcutlass is offline
Old July 17th, 2015, 02:22 PM
Tedd Thompson's Avatar
X2 if the top and bottom are still in good shape have it re cored and it will probably go another half century...Tedd
Tedd Thompson is offline
Old July 19th, 2015, 11:29 PM
47 Convertible's Avatar
X3 what Eric and Tedd said. Any competent radiator shop can diagnose the problem and give you an estimate to repair/rebuild. They can recore if necessary and if its a leak in the tank somewhere they can probably solder that unless the tank is paper thin from corrosion. Just drain, pull and take that radiator to a decent shop in your area. Other hot rodders or mechanics in your area will probably have an idea who is competent.
Jerry
47 Convertible is offline
BeenThere
March 5th, 2015 02:56 PM
1969goatman
June 14th, 2014 08:01 PM
Jims48
November 15th, 2012 04:26 PM
Al Graaf
March 24th, 2012 04:01 PM
citcapp
January 4th, 2009 06:03 AM
Quick Reply: 1948 Oldsmobile radiator leak
