1948 Oldsmobile radiator leak
Just sprung a leak in my radiator. Looks like it is coming from near the top. I have to take the cowl off to verify. In the meantime, does anyone know where I can get a replacement or have this one rebuilt. The car is a street rod so I don't necessarily need original, just bolt up compatible. Any info would be appreciated
X3 what Eric and Tedd said. Any competent radiator shop can diagnose the problem and give you an estimate to repair/rebuild. They can recore if necessary and if its a leak in the tank somewhere they can probably solder that unless the tank is paper thin from corrosion. Just drain, pull and take that radiator to a decent shop in your area. Other hot rodders or mechanics in your area will probably have an idea who is competent.
Jerry
Jerry
