1950 Olds turn signal wire
Old February 4th, 2023, 04:05 PM
carnutz's Avatar
Need some help. While I was doing some under dash cleanup, a wire became detached. One end of it was connected to the ignition switch, but I have no idea where the other ends goes. All I know is that the turn signals worked prior to this and now they don't. The wire is about 11" long.
Any help would be appreciated.
carnutz is offline
Old February 4th, 2023, 11:44 PM
Tedd Thompson's Avatar
That doesn't look like an original wire for fifties Oldsmobile is this an add-on turn signal? I would think it would be braided wire...Tedd
Tedd Thompson is offline
Old February 5th, 2023, 06:45 AM
carnutz's Avatar
The entire harness has been replaced many years ago with a reproduction harness of the original. This wire does have a woven fabric outer layer. It also has a fuse in the center of it.
Regardless if it is original or not, where does the power go to activate the turn signals?
Thanks,
carnutz is offline
kan4club
February 14th, 2022 05:02 AM
cfair
September 30th, 2021 12:27 PM
joe_padavano
July 28th, 2021 12:16 PM
72cutlassdog
August 13th, 2013 12:12 PM
1967cutty
June 14th, 2012 06:28 PM
Quick Reply: 1950 Olds turn signal wire
