1951 Olds 303 ci Starter/Flywheel Issue
Old June 6th, 2017, 11:18 AM
Mrs4J's Avatar
This engine is in a rat-rod. The engine has been bored and stroked to a 383 (I think) it has a 176 tooth flywheel. The original starter will not work as it is hitting flywheel, original flywheel had 145 teeth according to research. Bought another starter with a finer gear; but it did the same thing. My Husband said it sounds like it is hitting the flywheel and not engaging.
Does ANYONE have any suggestions or knowledge on this subject. I'm just a wife trying to help her Husband finish his project and get it on the road Any help will be truly appreciated. Thank you
Mrs4J is offline
Old June 6th, 2017, 12:03 PM
Mrs4J's Avatar
Mrs4J is offline
Old June 6th, 2017, 12:58 PM
Phantom Phixer
Charlie Jones's Avatar
Olds used three different ring gears on their early 'Rocket" V-8s
49 thru 53 used a 145 tooth ring gear .
54 thru 60 used a 176 tooth ring gear .
61 thru 64 used a 166 tooth ring gear.
Every time they changed the ring gear they also changed the design of the lower bellhousing , where the starter mounts , as well as the starter itself .
If you have a 176 tooth flywheel , then you will need to have a 54 thru 60 lower bellhousing and starter .
Charlie Jones is offline
Old June 6th, 2017, 03:21 PM
Tedd Thompson's Avatar
Here is a long link with more than a little info on the first generation Old's engines.You can take a break and read for a hour more on what hot rodders have been doing to these engines for years... Tedd
https://www.jalopyjournal.com/forum/...summary.47584/
Tedd Thompson is offline
Old June 6th, 2017, 03:46 PM
Mrs4J's Avatar
Flywheel
Thank you for the info Charlie. Can you look at this photo and tell me if this is the correct flywheel for a 1951 303 ci Oldsmobile? From what I understand the Cadillac and Olds were interchangeable at this time??
Mrs4J is offline
Old June 6th, 2017, 04:47 PM
Phantom Phixer
My parts book shows the part number 8611546 as the correct part number for a 49 thru 53 Oldsmobile with a V-8 and Hydra-Matic flywheel .
Besides that , the price is "out of this world " , keep looking .
What type of transmission do you have ? Standard or Hydra-Matic ?
If Hydra-Matic , slant pan or straight pan ?
The 49-53 bellhousings were rumored to be the same . Not necessarily the flywheels .
Old June 6th, 2017, 06:31 PM
Mrs4J's Avatar
It's a hydra-matic flat pan. Do you have any ideas where to get that exact flywheel??
Mrs4J is offline
Old June 6th, 2017, 07:03 PM
Phantom Phixer
Any 49 thru 53 V-8 Olds with Hydra-Matic .
You might try a parts wanted ad on this forum . Also in some other places such as Hemmings Motor News and the H.A.M.B.
Old June 7th, 2017, 12:36 PM
74 2.8L Capri
DFitz's Avatar
There are specific year experts as members of N.A.O.C. National Antique Oldsmobile Club. http://www.antiqueolds.org/ If you aren't a member it might be worth the investment.
They have a pretty good newsletter and an advertising section for parts. It might take a while to get an answer, but the model year experts are pretty good.
DFitz is offline
Old June 7th, 2017, 12:42 PM
Contact Ross Racing Engines, they may be able to point you in the right direction.
https://rossracingengines.oursafeserver.com/
oldcutlass is offline
Old June 7th, 2017, 01:59 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Worth mentioning is that Olds used dynaflows in 1953 because the hydra-matic plant burned. I have no idea of what the flywheel was like but I bet it was different. I doubt that is the case here.
redoldsman is offline
Old June 7th, 2017, 05:55 PM
X2 on Ross racing engines and ask for Tony (he will probably answer the phone anyway) they manufacture new parts and build engines for these old rigs....Tedd
Old June 8th, 2017, 05:41 AM
TRWham's Avatar
I think you need to be absolutely sure what you have. The cylinder head looks like an "8", so that could be a '55.
TRWham is offline
Old June 8th, 2017, 07:21 AM
Yep looks like# 8 on the head unless it is a #3, but a 55 head could be on a 53 block or it could be a 324. Many changes could have been made in 60 + years especially on a hot rod..... Tedd
Old June 8th, 2017, 04:20 PM
junkmanjr's Avatar
Contact Tony at Ross Racing he makes a mini starter for both 176 and 145 tooth flywheels probably cheaper and easier than changing the flywheel
junkmanjr is offline
Old June 9th, 2017, 03:54 AM
74 2.8L Capri
DFitz's Avatar
BTW, very nice shop!
DFitz is offline
Old June 10th, 2017, 07:02 AM
Ozzie's Avatar
You may have a case of chaos confounded by confusion. I can't find an interchange between Olds 303 & Cadillac flywheels. The Hollander number for the 1951 Olds 303 flywheel with Hydramatic is 69, and it interchanges with 1949-1953 Olds 303 with Hydramatic only. If it has the 176 toothed flywheel and the #8 heads (1955), what makes you think that it is a 1951 303? Flywheels for the 303 are available at some salvage yards throughout the country, but may not resolve the problem if matched with other incompatible components. Knowing the "history" of this engine might shed some light on the problem. You could try taking measurements of the relationship between the flywheel and the starter mount on the bell housing and try to match to a compatible starter at a shop that sells only starters (& perhaps generators). Those fellows sometime have a lot of insight into how to make mismatches work.
Ozzie is offline
Old June 10th, 2017, 07:11 AM
Or post the engine number, that might help define the year of the block. I think I have the numbers for the 55 series of engines Others may have the rest...... Tedd
Shot Gun Rich
January 2nd, 2016 11:15 AM
flatoz
April 24th, 2008 05:59 AM
jerry d
April 18th, 2006 05:05 AM
Quick Reply: 1951 Olds 303 ci Starter/Flywheel Issue
