1955 Olds 98, Bendix or Moraine Power Booster?
We have a bad Power Brake Booster on our 1955 Oldsmobile 98. Trying to figure out if it is a Bendix or a Moraine. We can't find a name on it. Any idea from the pictures, which it is. Thanks, Sandy
You can distinguish the difference between the two by putting a magnet on the body of the power booster . The Bindex unit is aluminum body and will not be attracted to the magnet, the Muriane will stick.... Tedd
Last edited by Tedd Thompson; May 22nd, 2022 at 07:39 PM. Reason: I'm dumb and caint tell the differance between a booster and a master
I have a Moraine unit in mine. I sent it out for a rebuild years ago. My original had a flat blade dipstick, when I got it back it had the triangle dipstick that was pit marked on the stick. Whenever I check the brake fluid, I worry that the triangle will break, I put anti seize on the threads. So apparently either type dipstick will work. I sure wish I had my original back.
Rick
Rick
Now back to our original thread, already in progress.
