1956 88 four door sedan
Old May 31st, 2019, 11:19 AM
  #41
tricordati's Avatar
Originally Posted by classicmuscle.442
Yes, it was a remote oil filter that was mounted on the passenger inner fender. One line was hooked to stock oil filter housing and the other to a small port on front of block by water pump. Both lines were plugged with sludge.
Now it makes sense...thanks.
tricordati is offline
Old August 11th, 2019, 07:36 PM
  #42
classicmuscle442's Avatar
Been driving car a while, she overheated yesterday, cleaned out radiator and flushed system. Had to solder a small leak around the cap mount. When out to check out car and smelled gas. The flexible fuel line that attaches to fuel pump was rotted out, replaced with a short section of fuel line. Engine is running better but getting some rocker noise. Will do another oil change after I replace valve cover gaskets.
classicmuscle442 is offline
johnreb49
April 16th, 2019 11:26 AM
TheBigBlueBoat
Brakes/Hydraulic Systems
January 13th, 2016 06:02 AM
OldsmobileKid
April 7th, 2015 04:50 PM
VI Cutty
16
August 21st, 2014 10:19 AM
tmatador
29
October 10th, 2011 05:47 AM
Quick Reply: 1956 88 four door sedan
