1957 Oldsmobile - trunk spring/tension rods
Old March 11th, 2024, 07:45 AM
WikedOldsmoileSupe88's Avatar
I removed my trunk springs because the original trunk lid on my 1957 Oldsmobile Super 88 2 door was so rusty I was afraid it would bend off when trying to close it. Over the weekend I was able to find a very nice used trunk lid to replace the old one. Was able to mount up all the old hardware and get it to open/close nicely. However, was not able to get the trunk lid rods back in place and attached to the hooks on the hinge springs. Is there a trick or certain steps to get those mounted correctly? Seems like they are under a lot of tension and just trying not to crush a finger!!! Thanks in advance for any help or guidance.
WikedOldsmoileSupe88 is offline
Old March 11th, 2024, 12:06 PM
ub2693v's Avatar
Can it be accessed with the rear seat back removed? i think there is a piece of cardboard that would have to be removed first but with the trunk lid shut there should be very little tension on the rod. Not sure if that is even possible but might be worth a shot.
ub2693v is offline
Old March 12th, 2024, 08:14 AM
I'll take a look and see. Thanks for the suggestion.
Old March 13th, 2024, 07:41 AM
Tried accessing the trunk springs from the back seat. Did not seem like it would work. I can see all the parts but just no real way to hook things up.
Old March 13th, 2024, 08:47 AM
OLDSter Ralph's Avatar
Have you checked CSM or Fisher Body manual ? I recall a thread in the past about this. There might be a special tool or "work around" to do what you need. You are referring to tension or torsion rods and not springs ?
OLDSter Ralph is offline
Old March 13th, 2024, 01:06 PM
Hi. Yes, the tension rods that help lift the trunk lid. I've seen instructions for other cars and most require a special tool.....or be risky and use vice grips and pry bars. Was trying to avoid that.
Old March 18th, 2024, 11:35 AM
Nomadoc's Avatar
How about a picture of what you have?
I don’t recall that this was a difficult procedure
Bill
Nomadoc is offline
Old March 18th, 2024, 03:37 PM
Thanks. Yes, it looks similar to what you posted. I was able to get the tension rods on this weekend. Took some serious effort with a prybar and a big screw driver plus a dead blow hammer but it's all back together. Thanks to everyone for you help.
Old March 19th, 2024, 08:35 AM
Wally's Avatar
Here is a tool I made just for that purpose. The small end just fits over the end of the rod and makes quick and easy adjustments to the position.
Wally is offline
Old March 19th, 2024, 09:24 AM
Thanks. Looks like a relatively easy tool to make. Just some plumbing parts!!
Old March 19th, 2024, 10:58 AM
Here are two additional threads which my help.
https://classicoldsmobile.com/forums...d-rods-146175/
https://classicoldsmobile.com/forums...install-87492/
Vintage Chief is offline
Old March 20th, 2024, 08:37 AM
Thanks. That looks very helpful for future repairs!!
Old March 21st, 2024, 01:05 PM
Tool Freek
BobsFiftyEight's Avatar
@Wally I love the homemade tool.
Bob
BobsFiftyEight is offline
Chuxter
Body work
August 15th, 2023 09:14 AM
Chuxter
March 10th, 2023 10:26 AM
Josh Pawnell
December 4th, 2018 04:46 PM
bigred1972
April 3rd, 2017 04:01 PM
tcarroll
February 19th, 2012 06:57 PM
Quick Reply: 1957 Oldsmobile - trunk spring/tension rods
