371 Engine Clearance
Old October 23rd, 2023, 01:36 AM
dokurobee's Avatar
私は 1957 年製オールズモビル 371 エンジンを再構築中です。
メインベアリングとロッドベアリングの隙間を教えて下さい。
I'm rebuilding a 1957 Oldsmobile 371 engine.
What is the gap between the main bearing and the rod bearing?
Last edited by oldcutlass; October 23rd, 2023 at 04:47 AM. Reason: edited in translation
dokurobee is offline
Old October 23rd, 2023, 04:58 AM
dokurobee's Avatar
I don't understand it even after reading the manual.
In particular, the clearance of rod bearings is complicated.
Old October 23rd, 2023, 09:10 AM
Tedd Thompson's Avatar
I need a little more information, Is this a stock 371 crank rod combo or a punched out 324? Do you have the new parts now? Is there an equivalent to what we have here in the states called Plastic Gauge where you are located ( Plastic tape used to measure bearing clearances)?. In general about 2- 3 thousands for rods but you need to check this with the correct manual, it doesn't sound like you have a compleat detailed manual for internal engine parts for your engine Or something is lost in translation.. Tedd
Tedd Thompson is offline
Cossack
August 3rd, 2022 02:31 AM
Rowdies
April 11th, 2012 09:23 PM
Hal Robinson
Tech Editor's Desk
January 26th, 2010 10:32 AM
loosecannon39
February 11th, 2009 08:02 PM
Kennybill
February 11th, 2009 12:34 PM
Quick Reply: 371 Engine Clearance
