'53 Super 88 Trunk Light
Old August 30th, 2012, 06:43 AM
CO53Super88's Avatar
My car has a light fixture on the driver's side trunk lid and it isn't working. I checked the bulb and it looks good, as does the fixture. I'm thinking it could be the switch but I can't find it anywhere. Should I be looking for a plunger-type switch that actuates when the trunk lid is lifted? Can anyone verify this and where the switch is generally located?
Thanks.
CO53Super88 is offline
Old August 30th, 2012, 08:13 AM
Collector of Stray 55's
Olds Dad's Avatar
There is a mercury switch inside the housing that makes contact when the lid is open - I took mine apart, cleaned the contact surfaces, put some dielectric grease on it, and it works great.
Be careful you don't drop the switch - it's a glass tube with mercury in it - looks like an oversized glass fuse.
Also, the lead wire to it (at least on my '55s) is only powered when the lights are on - so you should at least verify when (and if) you've got power to it.
Fun and easy little project - biggest challenge is popping open the housing.
Olds Dad is offline
Old August 30th, 2012, 08:23 AM
Aha! Great info. I've never had the car running or lights on when I've been in the trunk so I wouldn't be surprised if it works and I just don't know it. I will check and then do as you suggest if in fact it isn't working.
Thanks a bunch!
1957 Super 88
June 1st, 2013 03:21 PM
Ddbord
May 6th, 2013 06:12 AM
burtonantiqueautoparts
February 22nd, 2013 05:57 AM
valmaye
February 19th, 2012 10:41 AM
aholiday
January 11th, 2010 05:57 AM
Quick Reply: '53 Super 88 Trunk Light
