55 olds 98 passenger side air box removal
Old January 1st, 2021, 01:46 PM
dahl1car's Avatar
What holds the out side box on after screws are removed. Is there something inside holding it also.
dahl1car is offline
Old January 1st, 2021, 03:02 PM
Frank Ignachuck
ignachuck's Avatar
the "outside air box" is held on by an awful stuff known as "goop" for lack of a more technical term. You will have to gingerly pry that off and It will not be easy. The more important question is "why do you want to remove it"?
ignachuck is offline
Old January 1st, 2021, 04:23 PM
dahl1car's Avatar
I'm doing a frame off paint i need to clean up the firewall and every thing else.
dahl1car is offline
Old January 1st, 2021, 04:27 PM
dahl1car's Avatar
The air box im talking about is the fan motor box .
dahl1car is offline
Old January 2nd, 2021, 07:41 AM
Tedd Thompson's Avatar
Use a heat gun to soften up the goop. They are sometimes a bitch to get off around the radiator core from inside the interior air box some times needs to be heated up to get to the goop it gets like cement after a half a century or more....Tedd
Tedd Thompson is offline
Old January 2nd, 2021, 04:41 PM
dahl1car's Avatar
dahl1car
Thanks for the reply & information I finally got it off. You were right it was stuck on.
dahl1car is offline
55ash
June 28th, 2013 11:54 AM
Erinyes
June 9th, 2012 09:05 AM
501Paratrooper
June 8th, 2012 08:24 AM
dennisspeaks
September 28th, 2011 07:17 PM
Dreamworks
Suspension & Handling
October 21st, 2010 07:58 AM
Quick Reply: 55 olds 98 passenger side air box removal
