55 olds hydramatic
#81
As I mentioned in post #39, the manual says:
Nature: "Transmission shifts satisfactorily through 2nd and 3rd speeds (Dr range), but will not shift into 4th speed (Dr range)."
Cause: " Sticking 3-4 shifter valve and/or governor valves."
Correction: "Completely disassemble and inspect valve body and governor assemblies".
Sounds like you spent a lot of time of the 3-4 shifter valve. Have you completely disassembled the governor assembly and inspected cleaned it?
#82
#83
and no I have not removed the governor because it sounds like there’s 2 and I’m not sure which one to remove
#84
See the illustration below.
The thing about these spool valves, is that they fit in their bores to very close tolerances.
At least ten thousands of an inch and maybe up to 100 thousandth tolerance.
Debris so small you can't see it can still cause problems.
check the paragraph below.
Quote; " It can be assumed that the valves and plugs are free in their operating positions.
If they will fall of their own weight in their respective bores when the valve body is shaken slightly."
#85
There are at least two, but they're both in the same valve body.
#86
when I cleaned the valve body I made sure all pieces were cleaned and slid back in there place with no restrictions. What about this governor that’s behind the parking bracket? Is that messing up my 4th gear? Do I need to clean it? And that rear servo I think it’s attached to the case and the bands.
Note that parts #27, 41 & 42 comprise the 3 to 4 shift valve.
Th entire valve assembly has to come out to be cleaned.
As others have mentioned, ultrasonic cleaning is best.
#87
I cleaned all those parts. I’ll do it again I guess, but there has to be another part of the trans that also controls this 3-4 shift and if I’m opening it to clean the valve body again might as well do what else controls that shift I just need to know what exactly. Governor behind parking bracket or the servos front and or rear?
#88
#89
im just trying figure out how it came off when the pan came off? It must go on the outside of that shifter selector. But does it go over that little pin or under it. Just doesn’t make sense how it could fall off when I took the side pan off. If anyone else has an idea of what other part I must take off and clean next time I try this operation, please jump in. And I even been watching the videos of the hydramatic rebuild on YouTube which I think that guy has commented on this post his username looks familiar. But I didn’t hear him say a lot of explanation on what each parts do.
#92
A basic knowledge of hydraulics is helpful.
The front and rear servos apply the bands. The fact that you're getting 3 gears rules them out as a problem.
Yes, the " governor behind the parking bracket " is another valve body and should be entirely disassembled and cleaned thoroughly.
"Decisions " on when to change gears are driven by the pressure on certain valves. The pressure is created by the front and rear pumps.
It is modulated by the TV control and the gear selector (NDSLR)
Make sure all those governor valves slide freely, especially the 3 to 4 valve , # 41 on the illustration.
#93
The early Hydra-Matics were hydromechanically controlled.
#94
Hydramatic 3rd and 4th Speed Charts
The attached diagrams might help clarify what is going on between 3rd speed and 4th speed. Basically, the rear unit doesn't change state (clutch is on in 3rd and stays on in 4th). The front unit changes by applying the clutch and taking the band off, so both clutches are applied and both bands are off.
From the diagrams, the things that can stop the front unit from going from band on/clutch off, to band off/clutch on are:
- Pressure Regulator (not developing enough pressure?)
- Governor (stuck/not providing enough pressure?)
- Double transition valve (stuck?)
#95
And do I need any special tools to install it back in?
#96
#98
The most likely candidate to resolve your issue is going to be a new transmission since it's likely the rear transmission band has broken. Simply pointing out the basic truth straight-away up front.
NOTE: In the URL link I sent to you what Glenn (redoldsman) states:
If you can find a 55 transmission fine, if you can find a 54 transmission even better.
#99
Chris,
When you get brave enough to tackle tearing down the valve, I would suggest you invest in an Ultra Sonic Cleaner. You can get a small one at Harbor Freight for about $90. It's the only way to go when you want to get small parts clean. All you need is warm water and a shot glass of Simple Green. The parts will come out looking like new. Just make sure you take lots of pictures as you take the valve apart. The diagrams in the manual are very detailed but you need to make sure you identify each spring and each valve spool as you take the valve apart.
I've done a couple valves so if you need help just let me know.
Wally
Wally
#101
so it could be the front band not releasing or could be the pressure regulator? Cuz my VB is spotless as should be. I know it’s all been stated before I’m just having a hard time understand it.
#102
scharpp
October 8th, 2014 05:55 PM
