'55 S88 - Parts Suggestions
Hi All - I need to replace the shocks, spark plugs & battery. Would you lend me your expertise/suggestions on what to get. There are so many options out there, in this revival of my Olds, that I'm getting quite overwhelmed! Thank you
Here's a start......
https://www.rockauto.com/en/catalog/...cid+v8,1435706
I've used the ones that Fusick stocks on the shocks, I think they are made by Garble and they have held up well. Is this going to be a points show car or just a nice driver, makes a difference on score if you are going top end concourse or points car what battery, tires, even floor mats you use. If it's a show and shine (preferred) car it doesn't matter. I run AC plugs and the battery isa Delco Remey, I think it is a 64 series, check on that it maybe a 62 series either one ill work, but one is expensive one is what the car came with the other is easy to find anywhere and only is important if you are chasing points for a show. I need to know what your plans are for your cat sometimes it matters, usually for a driver car not so much, glad to help if I can...Tedd
Checkout the Oldsmobile page on https://www.vintagepartsource.com , there is a large list of Oldsmobile parts suppliers.
