6 volt or convert to 12 volt
Finally getting to work on, my 1950 olds 88 holiday coupe,it took along time to get it here,with all the run around I got from the tranporter.It is a 6 volt,it did not come with a battery.New 6 volt cost $120.00 or on E-BAY convert to 12 volt for $285.00 .what do you guys think??????????????
thanks
thanks
12 volt will be less sensitive to trouble from corrosion and poor connections, and a bit easier to get bulbs in a pinch. Also easier if you want to run a modern radio. Or GPS. Or TV. Or phone charger. Or DVD player. Or kids' video games. Or iPod. Or...
Your choice, really. If you need a battery anyway, all you need to change are the lightbulbs, blower motor, generator, and regulator (assuming you have vacuum wipers), and use a converter for the original radio if you want to use it.
If I were planning to drive it regularly, I'd probably change it over, but, remember, people drove millions of miles in these things with 6v systems and survived.
You could put an 8 volt battery in it and adjust the voltage regulator or get somebody that knows what they are doing to adjust it. If it were mine and I was going to be driving it a lot, I would change to 12 volts. Eric covered most of it above. I would use a 1 wire alternator. The wiring is fine as are the gauges. The starter will be okay but you will need to get a 54 - 56 starter solenoid.
Really nothing wrong with a 6 volt system. The biggest problem people have is they use 12 volt battery cables and they won't carry quite enough juice for reliable starts.The correct cables and clean connections and a 6 volt system will run for ever and they still are....Tedd
I still run 6 volts in the coupe, just ensure the battery is good. I like to keep it preseved as much as possible. Once modified, it can be very challenging to bring it back to the factory configuration. JMO....
For clarification, from a practical standpoint, I would totally understand why one would be interested in converting. Especially if you drive your car at night. I do not drive mine at night, when I've turned on my headlights I usually say "whoa, those things are dim!!" Other obvious considerations would be supplying cranking amps to a more modern powerplant. No disrespect intended for non purists, drive it, enjoy it, share it, you will never know when you might inspire someone.
vistacruiser1971
November 9th, 2013 01:19 PM
